Date/Time: Tue, 25 Feb 2025 17:16:30 +0000
how to recompile the Levex.dll file
View Count: 601
[2021-04-25 22:48:02]
User682444 - Posts: 12
I downloaded a cpp file from cumulative delta and price bar divergence
did the Analysis/build custom study using remote build which worked
However when I went to add the study there is a message under the study saying " custom study c:\sierrachart\data\levex.dll needs to be recompiled to be used on this version 2245"
I note that there is also a Levex_64.dll and wonder if it should be used instead of Levex.dll
I attempted to recompile Levex.dll using the Analysis/build custom study but
the file box keeps adding .cpp after the .dll and thus the file cannot be found.
The study I am adding is DelDivatBar1
Is there a way for me to recompile Levex.dll
[2021-04-25 23:58:33]
Sierra_Chart Engineering - Posts: 18564
No, you are not able to recompile that DLL because you do not have the source code for it. We do have a source code for it. It is associated with Cannon trading.
Since you already have the 64-bit version of it, delete this one:
