Date/Time: Tue, 25 Feb 2025 19:34:11 +0000
ZIGZAG on Numbers bar
View Count: 565
[2021-04-24 23:38:08]
User682444 - Posts: 12
I have used both calculation 2 and 3 and this occurs frequently but not all the time
If in a down trend; (or uptrend) the direction will sometimes change even though the next bar is lower (higher for an uptrend)
for the attached chart
Calculation is 3
reversal 17
number of bars required 1
I have circled two points where the bar after the direction turn has a lower low.
imagezigzag numbers bar.PNG / V - Attached On 2021-04-24 23:36:40 UTC - Size: 228.62 KB - 262 views
[2021-04-26 21:03:08]
Duplicate that chart with Chart >> Duplicate Chart, and remove all studies other than the zigzag study and then post an image of the chart at that particular date-time range.
Date Time Of Last Edit: 2021-04-26 21:04:27
