Date/Time: Fri, 28 Feb 2025 04:39:48 +0000
Letters/Blocks In Own Column (Default)
View Count: 1004
[2021-04-24 04:21:31]
chinfx - Posts: 3
Hi, how do I make this function on my TPO chart "Letters/Blocks In Own Column" to be set as my default settings? Everytime a new period comes along, the settings will always reverts back to standard profile and will mark "Letters/Blocks In Own Column" as unchecked.
[2021-04-24 20:11:23]
We will implement a solution to this.
[2021-05-03 11:54:24]
chinfx - Posts: 3
Any update/progress on this so far?
And also to add, not only an automatic update on "Letters/Blocks In Own Column" but as well as on "Letters/Blocks In Own Column - All Profiles" function. It is very challenging and I will have to do it manually particularly on lower timeframes when these features doesn't automatically update everytime a new period opens.
[2021-07-09 18:18:01]
whats1thingnow - Posts: 407
yes please add "Letters/Blocks In Own Column" to be the default of the chart
i forget to change it to own column sometimes so having it set to default would REALLY HELP
i like to keep my evening session profile collapsed, but for the day session, i want to have it by default "Letters/Blocks In Own Column"
if that's not possible, then "Letters/Blocks In Own Column - All Profiles" by default would work too
thank you
[2021-07-10 01:15:54]
Sierra_Chart Engineering - Posts: 18594
This has been already implemented. From documentation:
When Letters/Blocks In Own Column - All Profiles has been enabled, and all TPO profiles are displayed with Letters/Blocks displayed in individual columns, then when a chart replay is performed, any new added TPO Profiles to the chart will also have Letters/Blocks displayed in individual columns.
[2021-08-06 03:03:30]
chinfx - Posts: 3
Thank you Sierra and engineers. Your customer service and problem resolution is top notch!
