Date/Time: Tue, 25 Feb 2025 17:31:22 +0000
adjusting my chart
View Count: 487
[2021-04-23 15:23:29]
User431357 - Posts: 27
im in a chartbook setup that displays ten tic , 5 tic , footprint , and two more charts . My problem is im trying to squeeze in my heatmap but when i click on it to expand then restore it down so i can adjust it to fit in with the rest of the charts i cant find it when i hit restore ???
[2021-04-23 18:00:24]
John - SC Support - Posts: 38163
It sounds like your chart with the Market Depth Historical Graph is detached from your main Sierra Chart window. So when you minimize it, the minimized window will be in your Windows Task Manager, and not within the Sierra Chart program. Refer to the following to help your specific issue, but the rest of the page contains good information as well that you may need:
Detaching and Attaching Chart Windows: Setting Detached Chart to Always Be Visible
