Date/Time: Tue, 25 Feb 2025 17:10:10 +0000
Cumulative sum in a time slice?
View Count: 832
[2021-04-23 13:02:11]
Ben A - Posts: 123
Is it possible to do a cumulative sum of study but for resetting after x period of time?
For example, cumulative sum of study for 5 minutes then reset. I want the sums for each time slice.
Thanks!!
[2021-04-23 15:04:50]
John - SC Support - Posts: 38163
There is not a built-in study that can do this. You would need to develop it. You can start with the code for the "Cumulative Sum of Study" which is in Studies8.cpp which is in the ACS_Source directory under your main Sierra Chart installation. Refer to the following:
How to Build an Advanced Custom Study from Source Code
[2021-04-23 18:38:29]
Ben A - Posts: 123
Will a periodic summation work? Or is that a different calculation?
[2021-04-23 20:05:46]
What Periodic Summation are you referring to?
[2021-04-23 20:17:17]
Ben A - Posts: 123
There is a study called 'Summation- Periodic', just noticed there is also a 'Summation of Study Subgraph- Periodic'
Would any of those do what I want?
Many thanks!
[2021-04-25 07:41:14]
No those other ones work differently.
Do follow post #2. You can modify the existing study to do what you need.
