Date/Time: Tue, 25 Feb 2025 19:03:18 +0000
Sierra Chart Performance
View Count: 854
[2021-04-23 11:08:42]
User999835 - Posts: 33
From a performance standpoint, when you have a relatively large number of charts opened, is it better to have all the charts in one chartbook or spread across chartbooks or does it make no difference at all?
Thank you
[2021-04-23 15:02:32]
John - SC Support - Posts: 38165
It does not make a difference in terms of Chartbooks. But what can be helpful is to have multiple sub-instances of Sierra Chart to spread the load. Refer to the following:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.47 - Use Sub Instances to Distribute Processing Load
[2021-04-23 16:52:50]
Thank you, much appreciated.
[2021-04-26 18:49:45]
It can make a difference with operating system resources. If they are in different Chartbooks and you have set this option, then that reduces resources:
General Settings Window: Destroy Chart Windows when Hidden (Global Settings >> General Settings >> GUI >> Application GUI)
Date Time Of Last Edit: 2021-04-26 18:50:21
