Date/Time: Fri, 04 Apr 2025 08:39:13 +0000
DOM - how to show high/low of a time period
View Count: 1678
[2021-04-23 10:40:00]
MatZer0 - Posts: 36
I'd like to visualise time-based opening range directly on my DOM chart
Please take a look at my current DOM configuration, I highlighted in pink hypothetical opening range with low of 13777.25 and high of 13784.25 and I'd like to have it visualised by either some vertical lines above range high and below range low or by different background color for all rows in range.
Screenshot link:
https://drive.google.com/file/d/1H9NgVjQpywglygtAkaRsurriaXJ-1dMW/view?usp=sharing
How can I do so?
[2021-04-23 14:28:45]
ticinotrader - Posts: 410
Two possible options to try:
1. Use Chart Settings - Advanced Settings 2 - Copy Chart Drawings from Chart # option to overlay any drawing from other charts.
This overlays the Drawing left to the price scale of the DOM.
2. You can add the Initial Balance study to an external chart and overlay it to the DOM using the Study/Price Overlay study on the DOM.
Depending on the settings, this can display drawings, [1] left to the Price scale, [2] value labels on the Price scale or [2] text/value labels in the 'Label Column' of the DOM, if displayed.
Label Column can be vertically positioned as you like, similar to other DOM columns.
Hope this helps.
image20210423-162206.png / V - Attached On 2021-04-23 14:27:24 UTC - Size: 240.39 KB - 425 views
image20210423-162654.png / V - Attached On 2021-04-23 14:27:32 UTC - Size: 173.9 KB - 431 views
[2021-04-25 17:25:57]
Ticks - Posts: 206
If you want to learn a lot of tips and tricks for SC.
I recommend ticinotrader website.
https://www.ticinotrader.ch/
Date Time Of Last Edit: 2021-04-25 17:26:12
