Date/Time: Tue, 25 Feb 2025 17:12:24 +0000
How to access European stocks?
View Count: 973
[2021-04-23 10:04:40]
User197029 - Posts: 51
Dear SC Team
now that you have discontinued support for Teletrader I would like to know how one can display European stocks?
The option via Interactive Brokers should work in theory using tickers like this EBS-STK-SMART/VSE-EUR for example for the stock with the ISIN: AT0000652011 but in praxis SC has real issues to load the chart, in fact it doesn't load it. I know that you say this is because of the complicated way IB works but that doesn't solve my problem. Any suggestions? Will there be any other feed that will provide data for European Stock Exchanges. Thanks.
image23-04-21--120215 --1374.jpg / V - Attached On 2021-04-23 10:03:08 UTC - Size: 174.66 KB - 231 views
[2021-04-26 02:47:27]
You can access some European stock exchanges through the Sierra Chart Exchange Data Feed:
Regarding the problem with Interactive Brokers data, we really do not know. You really have to ask Interactive Brokers the contract specifications for a particular symbol and let us know what they say.
