Date/Time: Tue, 25 Feb 2025 20:17:50 +0000
EUREX micro ESTX50 - 1 euro / Interactive Brokers
View Count: 840
[2021-04-23 08:05:20] |
User877753 - Posts: 152 |
Hello, Could you set up micro Eurostoxx 50 for Interactive Brokers ? Only ESTX50 - 10 euro for now. Thanks in advance, Regards |
[2021-04-23 09:17:40] |
We looked for this symbol but could not find it. Can you provide us specifications for this contract from the Interactive Brokers website. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-23 09:17:47
[2021-04-23 09:34:15] |
ConId : 482048794 Here is the link : https://misc.interactivebrokers.com/cstools/contract_info/v3.10/index.php?action=CONTRACT_DETAILS&clt=1&detlev=2&site=IB&mid=001&conid=482048794 In cas you can't acess it, as I got it from TWS, see attached pdf. |
[2021-04-28 00:48:51] |
Thank you we apologize for the delay. We are adding this now.
[2021-04-28 21:44:11] |
This symbol has been added. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
