Date/Time: Sat, 01 Mar 2025 01:30:14 +0000
Request for a Fix of floating QuoteBoards
View Count: 546
[2021-04-23 07:07:11]
User391959 - Posts: 17
Dear SierraChart
I am member of a trading group, all using SC.
Many of our traders have the same issue and wish for a fix.
Therefore, we'd like requesting a fix for floating QuoteBoards.
It would be very beneficial if the QuoteBoard could have its fix position within a Chartbook --> same as chartbook window.
At the current state, the QuoteBoard keeps floating.
Whenever we move the SC Main Window on our screen, the QuoteBoard does not move and keeps it's position on the monitor. This is not practical and we need a fix for it!
i.e. it should be able to integrate a 'quote board' into a chartbook the same way as it is possible with 'chart windows'.
Thank you for looking at this request.
We appreciate your support
[2021-04-23 08:35:50]
User90125 - Posts: 715
Also, users should be able to PRINT any given QuoteBoard separate and independent of the main chart.
Could this be added?
Thanks.
[2021-09-10 09:56:33]
SC, could you kindly set these items as [Feature Request].
Thank you.
[2021-09-10 14:07:30]
John - SC Support - Posts: 38292
This has been set as a Feature Request.
