Date/Time: Sat, 04 Jul 2026 09:01:09 +0000
[User Discussion] - Get the lowest low of 5 past bars
View Count: 1539
| [2021-04-23 04:36:47] |
| Ticks - Posts: 212 |
Would anyone have a code block to get the lowest value of 5 past bars then convert that value to tics and place in an array? |
| [2021-04-23 08:50:36] |
| Ackin - Posts: 1865 |
study: Highest High / Lowest Low Over N Bars studies7.cpp in the ACS Source folder of your main SC install. |
| [2021-04-23 09:12:34] |
Yes, I have already looked at that study. Does not perform what i need. My trade entries are all limit orders that is offset by an amount of tics. I`m looking to have the offset dynamic that looks back at the amount of pullbacks after previous 5 trade entry signals. The lowest pullbacks are captured at 5 bars after every signal and placed in an array. Take average number of 5 array fields of tics captured in that array and use that average ticks as the offset for the current trade entry. Date Time Of Last Edit: 2021-04-23 09:53:36
| [2021-04-28 02:04:47] |
Unfortunately, no one was willing to provide a working code snippet. But, I was able to get what I needed working. On to the next coding road block to break thru. |
| [2021-04-28 04:29:42] |
| Sierra_Chart Engineering - Posts: 24161 |
These are the relevant ACSIL members to work with to accomplish what you want: ACSIL Interface Members - Functions: sc.GetLowest() ACSIL Interface Members - Variables and Arrays: sc.TickSize And also refer to: Working with ACSIL Arrays and Understanding Looping: Overview of sc.BaseData[][]sc.Subgraph[].Data[]sc.Subgraph[].Arrays[][] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-28 04:30:14
| [2021-04-28 09:19:24] |
Thanks. I will add the links to my collection.
