Date/Time: Tue, 25 Feb 2025 23:06:13 +0000
opengl and custom graphics
View Count: 809
[2021-04-23 00:32:42] |
jesslinn - Posts: 108 |
I understand that when opengl is activated that p_GDIFunction is no longer called. Is there any way to do custom graphics when use of opengl is enabled? Would it be possible to add a hook, similar to p_GDIFunction, that would call an ACSIL user code function after you have rendered the current graph but before the buffer is swapped. Wouldn't such a call allow user code to draw anything onto the back buffer with normal gl calls? It is a shame to have the huge improvement of using opengl available but not be able to use it because of the need to support custom graphics. Thanks |
[2021-04-23 02:12:51] |
Yes if you know what you are doing: Wouldn't such a call allow user code to draw anything onto the back buffer with normal gl calls?
We will have to look into this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-05 08:52:42] |
Any chance that such a hook could be added? I would be happy to test it out. I was able to use opengl through p_GDIFunction in the past but all ability to draw custom graphics goes away when one turns on opengl in SC. Thanks. |
