Date/Time: Tue, 25 Feb 2025 17:39:05 +0000
Incorrect fills displayed on chart
View Count: 434
[2021-04-22 17:04:37] |
User469888 - Posts: 4 |
There is a discrepancy on order fills displayed on my chart (TT) that just starting happening out of the blue and doesn't go away on platform restart. I'm attaching a screenshot on one of them.
Attachment Deleted. Private File |
[2021-04-23 01:55:10] |
Sierra_Chart Engineering - Posts: 18564 |
Refer to: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities That section comprehensively explains this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
