Date/Time: Fri, 02 Oct 2026 20:00:27 +0000
Not connecting to server
View Count: 770
[2021-04-22 16:12:53]
DougAtk - Posts: 1
Reading Internal Order ID file. | 2021-04-22 11:11:49.371
Reading Trade Orders file. | 2021-04-22 11:11:49.559
Reading Trade Positions file. | 2021-04-22 11:11:49.559
Reading Trade Account Data files. | 2021-04-22 11:11:49.559
UDPListener (1600). Port 22904 | Listening on UDP port 22904. | 2021-04-22 11:11:49.587
Software version: 2250 64-bit | 2021-04-22 11:11:49.587
Primary Thread ID: 7036 | 2021-04-22 11:11:49.587
Usage end date: 2021-08-06 | 2021-04-22 11:11:49.587
Enabled for: Advanced Features 2. | 2021-04-22 11:11:49.587
Enabled for: Sierra Chart Historical Data Service. | 2021-04-22 11:11:49.587
Enabled for: Delayed Denali Exchange Data Feed. | 2021-04-22 11:11:49.587
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-04-22 11:11:49.587
Current selected Data/Trading service: Global Data Feeds India - DTC | 2021-04-22 11:11:49.587
Custom symbol settings values: enabled | 2021-04-22 11:11:49.587
Chart Update Interval: 500 | 2021-04-22 11:11:49.587
Intraday Data Storage Time Unit: 1 | 2021-04-22 11:11:49.587
Time Zone: +00:00:00 (UTC+00) | 2021-04-22 11:11:49.587
2021-04-22 11:11:49 Local computer time in UTC | 2021-04-22 11:11:49.587
2021-04-22 11:11:49 Local computer time in SC Time Zone | 2021-04-22 11:11:49.587
2021-04-22 11:11:48 Server time in UTC | 2021-04-22 11:11:49.587
Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-04-22 11:11:49.587
Program path: C:\Users\douga\Downloads\SierraChart2250\ | 2021-04-22 11:11:49.587
Data Files path: C:\Users\douga\Downloads\SierraChart2250\Data\ | 2021-04-22 11:11:49.587
OS Version Number: 10.0 | 2021-04-22 11:11:49.587
Locale Setting: C | 2021-04-22 11:11:49.587
DLLs: UserContributedStudies_64.dll | 2021-04-22 11:11:49.588
Allowed protected custom studies: | 2021-04-22 11:11:49.588
Checking for new symbol settings. Requested symbol settings MD5 for service code globaldatafeeds_dtc.data. Request ID: 1. | 2021-04-22 11:11:49.588
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-04-22 11:11:49.672
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-04-22 11:11:49.790
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-04-22 11:11:49.790
Received 5 login tokens. | 2021-04-22 11:11:50.023
Symbol settings MD5 received. Request ID: 1. | 2021-04-22 11:11:50.064
Symbol settings are up-to-date for globaldatafeeds_dtc.data. | 2021-04-22 11:11:50.064
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:11:56.091
DTC Client socket (1) | Creating socket. | 2021-04-22 11:11:56.091
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:11:56.091
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:11:56.091
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:11:58.143 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:11:58.143
DTC Client socket (1) | Closed. | 2021-04-22 11:11:58.143
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:11:58.143
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:11:58.143
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:11:58.148
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:11:58.148
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:11:58.148
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:12:01.158
DTC Client socket (1) | Creating socket. | 2021-04-22 11:12:01.158
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:12:01.158
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:12:01.158
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:12:03.207 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:12:03.207
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:12:03.207
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:03.207
DTC Client socket (1) | Closed. | 2021-04-22 11:12:03.207
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:12:03.213
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:12:03.213
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:03.214
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:12:06.211
DTC Client socket (1) | Creating socket. | 2021-04-22 11:12:06.211
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:12:06.211
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:12:06.211
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:12:08.246 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:12:08.247
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:12:08.247
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:08.247
DTC Client socket (1) | Closed. | 2021-04-22 11:12:08.247
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:12:08.263
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:12:08.264
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:08.264
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:12:11.258
DTC Client socket (1) | Creating socket. | 2021-04-22 11:12:11.258
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:12:11.258
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:12:11.258
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:12:13.302 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:12:13.302
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:12:13.302
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:13.302
DTC Client socket (1) | Closed. | 2021-04-22 11:12:13.302
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:12:13.304
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:12:13.304
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:13.304
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:12:16.309
DTC Client socket (1) | Creating socket. | 2021-04-22 11:12:16.309
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:12:16.309
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:12:16.309
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:12:18.356 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:12:18.358
DTC Client socket (1) | Closed. | 2021-04-22 11:12:18.358
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:12:18.358
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:18.358
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:12:18.369
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:12:18.370
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:18.370
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:12:21.374
DTC Client socket (1) | Creating socket. | 2021-04-22 11:12:21.374
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:12:21.375
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:12:21.375
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:12:23.411 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:12:23.411
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:12:23.411
DTC Client socket (1) | Closed. | 2021-04-22 11:12:23.411
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:23.411
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:12:23.416
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:12:23.417
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:23.417
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:12:26.420
DTC Client socket (1) | Creating socket. | 2021-04-22 11:12:26.420
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:12:26.420
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:12:26.420
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:12:28.452 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:12:28.452
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:12:28.452
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:28.452
DTC Client socket (1) | Closed. | 2021-04-22 11:12:28.452
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:12:28.466
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:12:28.467
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:28.467
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:12:31.468
DTC Client socket (1) | Creating socket. | 2021-04-22 11:12:31.468
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:12:31.468
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:12:31.468
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:12:33.512 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:12:33.513
DTC Client socket (1) | Closed. | 2021-04-22 11:12:33.513
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:12:33.513
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:33.513
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:12:33.525
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:12:33.526
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:33.526
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:12:36.523
DTC Client socket (1) | Creating socket. | 2021-04-22 11:12:36.523
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:12:36.523
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:12:36.523
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:12:38.578 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:12:38.579
DTC Client socket (1) | Closed. | 2021-04-22 11:12:38.579
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:12:38.580
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:38.580
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:12:38.591
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:12:38.591
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:38.591
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:12:41.595
DTC Client socket (1) | Creating socket. | 2021-04-22 11:12:41.595
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:12:41.595
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:12:41.595
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:12:43.644 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:12:43.644
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:12:43.644
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:43.644
DTC Client socket (1) | Closed. | 2021-04-22 11:12:43.644
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:12:43.652
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:12:43.652
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:43.653
ESM1-CME #1 | Reloading chart. | 2021-04-22 11:12:46.387
NQM1-CME #2 | Reloading chart. | 2021-04-22 11:12:46.440
MYMM1-CBOT #6 | Reloading chart. | 2021-04-22 11:12:46.484
GCM1-COMEX #4 | Reloading chart. | 2021-04-22 11:12:46.525
CLM1-NYMEX #3 | Reloading chart. | 2021-04-22 11:12:46.566
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:12:46.650
DTC Client socket (1) | Creating socket. | 2021-04-22 11:12:46.650
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:12:46.650
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:12:46.650
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:12:48.685 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:12:48.687
DTC Client socket (1) | Closed. | 2021-04-22 11:12:48.687
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:12:48.687
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:48.687
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:12:48.698
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:12:48.699
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:48.699
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:12:51.697
DTC Client socket (1) | Creating socket. | 2021-04-22 11:12:51.697
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:12:51.697
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:12:51.697
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:12:53.731 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:12:53.733
DTC Client socket (1) | Closed. | 2021-04-22 11:12:53.733
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:12:53.734
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:53.734
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:12:53.747
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:12:53.747
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:53.747
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:12:56.744
DTC Client socket (1) | Creating socket. | 2021-04-22 11:12:56.744
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:12:56.744
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:12:56.744
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:12:58.780 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:12:58.780
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:12:58.780
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:58.780
DTC Client socket (1) | Closed. | 2021-04-22 11:12:58.780
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:12:58.789
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:12:58.789
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:12:58.789
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:13:01.791
DTC Client socket (1) | Creating socket. | 2021-04-22 11:13:01.791
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:13:01.791
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:13:01.791
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:13:03.828 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:13:03.829
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:13:03.829
DTC Client socket (1) | Closed. | 2021-04-22 11:13:03.829
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:03.829
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:13:03.837
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:13:03.837
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:03.837
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:13:06.838
DTC Client socket (1) | Creating socket. | 2021-04-22 11:13:06.838
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:13:06.838
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:13:06.838
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:13:08.880 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:13:08.880
DTC Client socket (1) | Closed. | 2021-04-22 11:13:08.881
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:13:08.881
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:08.881
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:13:08.884
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:13:08.885
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:08.885
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:13:11.886
DTC Client socket (1) | Creating socket. | 2021-04-22 11:13:11.886
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:13:11.886
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:13:11.886
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:13:13.920 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:13:13.920
DTC Client socket (1) | Closed. | 2021-04-22 11:13:13.920
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:13:13.920
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:13.920
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:13:13.935
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:13:13.935
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:13.935
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:13:16.940
DTC Client socket (1) | Creating socket. | 2021-04-22 11:13:16.940
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:13:16.940
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:13:16.940
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:13:18.969 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:13:18.969
DTC Client socket (1) | Closed. | 2021-04-22 11:13:18.969
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:13:18.969
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:18.969
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:13:18.984
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:13:18.985
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:18.985
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:13:21.977
DTC Client socket (1) | Creating socket. | 2021-04-22 11:13:21.977
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:13:21.977
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:13:21.977
Service is currently connecting. | 2021-04-22 11:13:22.686 *
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:13:24.012 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:13:24.012
DTC Client socket (1) | Closed. | 2021-04-22 11:13:24.012
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:13:24.012
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:24.012
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:13:24.027
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:13:24.028
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:24.028
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:13:27.030
DTC Client socket (1) | Creating socket. | 2021-04-22 11:13:27.030
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:13:27.030
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:13:27.030
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:13:29.069 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:13:29.070
DTC Client socket (1) | Closed. | 2021-04-22 11:13:29.070
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:13:29.071
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:29.071
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:13:29.085
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:13:29.086
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:29.086
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:13:32.091
DTC Client socket (1) | Creating socket. | 2021-04-22 11:13:32.091
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:13:32.091
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:13:32.091
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:13:34.136 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:13:34.161
DTC Client socket (1) | Closed. | 2021-04-22 11:13:34.161
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:13:34.163
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:34.163
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:13:34.184
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:13:34.184
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:34.184
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:13:37.179
DTC Client socket (1) | Creating socket. | 2021-04-22 11:13:37.179
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:13:37.180
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:13:37.180
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:13:39.230 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:13:39.230
DTC Client socket (1) | Closed. | 2021-04-22 11:13:39.230
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:13:39.230
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:39.230
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:13:39.246
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:13:39.247
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:39.247
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:13:42.243
DTC Client socket (1) | Creating socket. | 2021-04-22 11:13:42.243
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:13:42.243
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:13:42.243
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:13:44.289 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:13:44.289
DTC Client socket (1) | Closed. | 2021-04-22 11:13:44.289
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:13:44.289
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:44.289
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:13:44.304
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:13:44.304
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:44.304
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:13:47.308
DTC Client socket (1) | Creating socket. | 2021-04-22 11:13:47.308
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:13:47.308
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:13:47.308
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:13:49.348 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:13:49.348
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:13:49.348
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:49.348
DTC Client socket (1) | Closed. | 2021-04-22 11:13:49.348
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:13:49.354
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:13:49.354
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:49.354
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:13:52.356
DTC Client socket (1) | Creating socket. | 2021-04-22 11:13:52.356
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:13:52.356
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:13:52.356
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:13:54.393 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:13:54.393
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:13:54.393
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:54.393
DTC Client socket (1) | Closed. | 2021-04-22 11:13:54.393
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:13:54.404
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:13:54.405
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:54.405
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:13:57.406
DTC Client socket (1) | Creating socket. | 2021-04-22 11:13:57.407
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:13:57.407
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:13:57.407
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:13:59.456 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:13:59.456
DTC Client socket (1) | Closed. | 2021-04-22 11:13:59.456
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:13:59.456
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:59.456
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:13:59.464
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:13:59.465
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:13:59.465
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:14:02.469
DTC Client socket (1) | Creating socket. | 2021-04-22 11:14:02.469
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:14:02.469
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:14:02.469
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:14:04.504 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:14:04.505
DTC Client socket (1) | Closed. | 2021-04-22 11:14:04.505
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:14:04.506
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:04.506
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:14:04.516
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:14:04.517
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:04.517
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:14:07.517
DTC Client socket (1) | Creating socket. | 2021-04-22 11:14:07.517
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:14:07.517
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:14:07.517
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:14:09.547 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:14:09.548
DTC Client socket (1) | Closed. | 2021-04-22 11:14:09.548
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:14:09.548
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:09.548
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:14:09.554
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:14:09.554
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:09.555
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:14:12.559
DTC Client socket (1) | Creating socket. | 2021-04-22 11:14:12.559
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:14:12.559
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:14:12.559
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:14:14.576 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:14:14.730
DTC Client socket (1) | Closed. | 2021-04-22 11:14:14.730
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:14:14.731
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:14.731
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:14:14.774
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:14:14.774
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:14.774
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:14:17.796
DTC Client socket (1) | Creating socket. | 2021-04-22 11:14:17.796
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:14:17.796
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:14:17.796
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:14:19.822 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:14:19.823
DTC Client socket (1) | Closed. | 2021-04-22 11:14:19.823
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:14:19.824
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:19.824
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:14:19.837
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:14:19.837
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:19.837
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:14:22.845
DTC Client socket (1) | Creating socket. | 2021-04-22 11:14:22.845
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:14:22.845
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:14:22.845
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:14:24.904 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:14:24.904
DTC Client socket (1) | Closed. | 2021-04-22 11:14:24.904
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:14:24.905
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:24.905
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:14:24.921
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:14:24.921
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:24.922
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:14:27.922
DTC Client socket (1) | Creating socket. | 2021-04-22 11:14:27.922
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:14:27.922
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:14:27.922
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:14:29.957 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:14:29.957
DTC Client socket (1) | Closed. | 2021-04-22 11:14:29.957
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:14:29.958
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:29.958
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:14:29.970
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:14:29.970
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:29.971
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:14:32.960
DTC Client socket (1) | Creating socket. | 2021-04-22 11:14:32.960
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:14:32.960
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:14:32.960
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:14:34.994 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:14:34.994
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:14:34.994
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:34.994
DTC Client socket (1) | Closed. | 2021-04-22 11:14:34.995
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:14:35.014
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:14:35.014
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:35.014
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:14:38.016
DTC Client socket (1) | Creating socket. | 2021-04-22 11:14:38.016
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:14:38.016
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:14:38.016
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:14:40.048 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:14:40.048
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:14:40.048
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:40.048
DTC Client socket (1) | Closed. | 2021-04-22 11:14:40.048
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:14:40.054
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:14:40.055
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:40.055
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:14:43.066
DTC Client socket (1) | Creating socket. | 2021-04-22 11:14:43.066
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:14:43.066
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:14:43.066
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:14:45.110 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:14:45.112
DTC Client socket (1) | Closed. | 2021-04-22 11:14:45.112
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:14:45.113
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:45.113
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:14:45.121
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:14:45.121
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:45.121
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:14:48.120
DTC Client socket (2) | Creating socket. | 2021-04-22 11:14:48.120
DTC Client socket (2) | New receive buffer size: 5242880 | 2021-04-22 11:14:48.120
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:14:48.120
DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:14:50.139 *
DTC Client socket (2) | CloseSocket call. | 2021-04-22 11:14:50.140
DTC Client socket (2) | Closed. | 2021-04-22 11:14:50.140
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:14:50.141
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:50.141
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:14:50.151
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:14:50.151
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:50.152
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:14:53.157
DTC Client socket (1) | Creating socket. | 2021-04-22 11:14:53.157
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:14:53.158
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:14:53.158
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:14:55.195 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:14:55.196
DTC Client socket (1) | Closed. | 2021-04-22 11:14:55.196
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:14:55.197
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:55.197
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:14:55.210
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:14:55.210
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:14:55.211
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:14:58.225
DTC Client socket (1) | Creating socket. | 2021-04-22 11:14:58.225
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:14:58.225
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:14:58.225
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:15:00.265 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:15:00.266
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:15:00.266
DTC Client socket (1) | Closed. | 2021-04-22 11:15:00.266
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:00.266
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:15:00.281
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:15:00.282
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:00.282
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:15:03.276
DTC Client socket (1) | Creating socket. | 2021-04-22 11:15:03.276
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:15:03.276
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:15:03.276
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:15:05.326 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:15:05.328
DTC Client socket (1) | Closed. | 2021-04-22 11:15:05.328
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:15:05.329
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:05.329
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:15:05.340
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:15:05.340
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:05.341
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:15:08.339
DTC Client socket (1) | Creating socket. | 2021-04-22 11:15:08.339
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:15:08.340
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:15:08.340
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:15:10.371 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:15:10.371
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:15:10.371
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:10.372
DTC Client socket (1) | Closed. | 2021-04-22 11:15:10.372
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:15:10.387
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:15:10.387
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:10.387
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:15:13.388
DTC Client socket (1) | Creating socket. | 2021-04-22 11:15:13.388
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:15:13.388
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:15:13.388
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:15:15.438 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:15:15.438
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:15:15.438
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:15.438
DTC Client socket (1) | Closed. | 2021-04-22 11:15:15.438
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:15:15.451
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:15:15.451
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:15.451
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:15:18.446
DTC Client socket (1) | Creating socket. | 2021-04-22 11:15:18.446
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:15:18.446
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:15:18.446
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:15:20.480 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:15:20.481
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:15:20.481
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:20.481
DTC Client socket (1) | Closed. | 2021-04-22 11:15:20.481
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:15:20.497
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:15:20.498
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:20.498
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:15:23.496
DTC Client socket (1) | Creating socket. | 2021-04-22 11:15:23.496
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:15:23.496
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:15:23.496
The message log has been sent to support. | 2021-04-22 11:15:24.197 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. | 2021-04-22 11:15:24.197
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | New receive buffer size: 32768 | 2021-04-22 11:15:24.197
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Connecting to IP: 46.4.97.203. | 2021-04-22 11:15:24.197
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:15:25.543 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:15:25.543
DTC Client socket (1) | Closed. | 2021-04-22 11:15:25.543
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:15:25.543
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:25.543
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:15:25.555
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:15:25.555
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:25.555
Sending of the Message Log is completed. The response was saved to C:\Users\douga\Downloads\SierraChart2250\Data\MessageLogAnalysis.htm | 2021-04-22 11:15:25.768
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | CloseSocket call. | 2021-04-22 11:15:26.013
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Shutdown started. Waiting for graceful close. | 2021-04-22 11:15:26.013
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. | 2021-04-22 11:15:26.132
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Closed. | 2021-04-22 11:15:26.132
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:15:28.561
DTC Client socket (1) | Creating socket. | 2021-04-22 11:15:28.561
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:15:28.561
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:15:28.561
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:15:30.592 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:15:30.592
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:15:30.592
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:30.592
DTC Client socket (1) | Closed. | 2021-04-22 11:15:30.592
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:15:30.609
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:15:30.610
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:30.610
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:15:33.604
DTC Client socket (1) | Creating socket. | 2021-04-22 11:15:33.604
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:15:33.604
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:15:33.604
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:15:35.646 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:15:35.646
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:15:35.646
DTC Client socket (1) | Closed. | 2021-04-22 11:15:35.646
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:35.646
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:15:35.655
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:15:35.656
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:35.656
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:15:38.656
DTC Client socket (1) | Creating socket. | 2021-04-22 11:15:38.656
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:15:38.656
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:15:38.656
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:15:40.682 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:15:40.682
DTC Client socket (1) | Closed. | 2021-04-22 11:15:40.682
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:15:40.683
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:40.683
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:15:40.698
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:15:40.698
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:40.698
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:15:43.696
DTC Client socket (1) | Creating socket. | 2021-04-22 11:15:43.696
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:15:43.696
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:15:43.696
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:15:45.716 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:15:45.717
DTC Client socket (1) | Closed. | 2021-04-22 11:15:45.717
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:15:45.717
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:45.717
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:15:45.732
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:15:45.733
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:45.733
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:15:48.733
DTC Client socket (2) | Creating socket. | 2021-04-22 11:15:48.734
DTC Client socket (2) | New receive buffer size: 5242880 | 2021-04-22 11:15:48.734
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:15:48.734
DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:15:50.779 *
DTC Client socket (2) | CloseSocket call. | 2021-04-22 11:15:50.779
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:15:50.779
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:50.779
DTC Client socket (2) | Closed. | 2021-04-22 11:15:50.779
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:15:50.795
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:15:50.796
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:50.796
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:15:53.792
DTC Client socket (1) | Creating socket. | 2021-04-22 11:15:53.793
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:15:53.793
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:15:53.793
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-04-22 11:15:55.829 *
DTC Client socket (1) | CloseSocket call. | 2021-04-22 11:15:55.829
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-04-22 11:15:55.829
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:55.829
DTC Client socket (1) | Closed. | 2021-04-22 11:15:55.830
DTC Client socket (0) | CloseSocket call. | 2021-04-22 11:15:55.835
Global Data Feeds India - DTC | Disconnected. | 2021-04-22 11:15:55.835
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-04-22 11:15:55.835
Global Data Feeds India - DTC | Connecting to the server 127.0.0.1. Port 9090 | 2021-04-22 11:15:58.837
DTC Client socket (1) | Creating socket. | 2021-04-22 11:15:58.837
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-22 11:15:58.837
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-04-22 11:15:58.837
[2021-04-22 16:38:53]
You will need to follow through the instructions here to use Global Data Feeds:
Global Data Feeds (India) Data Service: Setup Instructions
Contact them for more help.
