Date/Time: Tue, 25 Feb 2025 17:18:28 +0000
CLEK21 Chart Activation
View Count: 591
[2021-04-22 16:11:26] |
User671813 - Posts: 2 |
I have extended and renew my CLE account but do not get an active charting feed
[2021-04-22 16:23:58] |
John - SC Support - Posts: 38163 |
We do not know what you mean by your "CLE Account". You are not setup to get any real-time data from us, so you should be getting it from CQG. Are you getting an error or other message on the screen when you try to open the chart for CLEK21? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-23 07:10:45] |
If you do want to use a Sierra Chart provided data feed, then refer to this page: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
