Date/Time: Sun, 27 Sep 2026 03:58:39 +0000
From AMP to Denali Pricing
View Count: 966
| [2021-04-22 15:19:00] |
| User811550 - Posts: 5 |
I have looked through the post and can not find the answer I'm looking for. I am with AMP and a non-professional I (was) getting Sierrachart from them and I have CME Level 2 bundled and CQG. I understand I pay directly to SC now for the Sierra chart $36. What is the total cost and break down to get the same thing I have now with AMP, and the Denali data feed through Sierracharts? Should I wait till the first of the month to save money? And how do I go about it, please? |
| [2021-04-22 15:25:03] |
| John - SC Support - Posts: 48028 |
Assuming that the CME Level 2 is equivalent to what we call the Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts, then your costs would be the following: - Sierra Chart Package 11: $46.00 USD / month - Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts: $31.20 USD / month Total: $77.20 USD / month You can reduce the cost of Package 11 by purchasing either 3 or 6 months up front. To add the Denali Exchange Data Feed, just follow the Setup Instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Yes, you should wait until the first of May to start the Denali Exchange Data Feed, otherwise, you will pay the $31.20 for the remaining 8 days of April and then have to pay it again on May 1. The exchange fees are NOT pro-rated. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-22 15:25:52
| [2021-04-22 17:02:42] |
Also refer to: How to: Reducing Cost of Real-time CME Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
