Date/Time: Tue, 25 Feb 2025 16:58:09 +0000
Denali TT - stop showing as client held
View Count: 438
[2021-04-22 14:53:04] |
User196369 - Posts: 41 |
I have moved back over to TT routing and am confused by the status of the stop component of a bracket order before the order is filled. The bracket is setup as: Stop: Stop, Target: MIT Client Before fill the Target: MIT Client status shows as Pending Child-Client which is as expected But the stop is also showing as Pending Child-Client. Does this mean the stop is held on my PC? It should be on the Sierra server from my understanding. Please confirm if I am misunderstanding or if I have configured something wrong. Server side bracket orders and OCO are both set to yes in trade settings. Neither the stop or target orders show up on the Trade Account and Order Entry web panel if that is relevant. Thank you |
[2021-04-22 15:02:10] |
Changing the MIT Client to a Limit shows both sides of bracket as server side. Is that a limitation, that if one part of bracket is client side then both are? |
[2021-04-23 19:14:06] |
Sierra_Chart Engineering - Posts: 18564 |
Is that a limitation, that if one part of bracket is client side then both are? Yes this is correct.
