Date/Time: Tue, 25 Feb 2025 17:07:51 +0000
Detached charts changing symbols
View Count: 428
[2021-04-22 05:02:59] |
User645832 - Posts: 99 |
Is there a quick way to change the symbol on a detached chart? The only way I know how to do it is to type the symbol in the chart settings. |
[2021-04-22 13:39:36] |
John - SC Support - Posts: 38163 |
Refer to the following: Changing the Symbol of a Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
