Date/Time: Thu, 17 Sep 2026 17:05:40 +0000
Daily High / Low Hit any time during day
View Count: 726
[2021-04-21 17:24:03]
Chadly - Posts: 65
I love the Daily High/ Low lines to actuate or be a piece of the recipe for alerts.
Is there a way to make it part of the recipe in this way:
If ever during the day the candle crosses daily high or low, then stochastic line is crossed and up (could be 3 or 5 or 2 candles after the high or low was crossed) then the alert is fired?
SO basically, if stochastic crosses and points in a direction if any previous candles or current candle crossed the daily high or low that day, it would fire an alert?
Is this possible?
THanks again!
[2021-04-21 17:30:43]
John - SC Support - Posts: 47926
You reference looking for an incident that occurred in the past. This is not something that is easy to do with the Simple Alerts. Therefore, you would need to look into using the Spreadsheet for Alerts instead.
Refer to the following in general:
Spreadsheet Systems, Alerts and Automated Trading
And refer to the concept of a "persistent variable" within the spreadsheet to let you know that the incident in the past has occurred:
Spreadsheet Example Formulas and Usage: Persistent and Incrementing Variables
