Date/Time: Tue, 25 Feb 2025 16:05:52 +0000
Number bars colored in the foreground
View Count: 623
[2021-04-21 16:36:36] |
ISB3 - Posts: 11 |
Hi, I have a footprint configuration with the number bar indicator that someone shared with me, I added it to my template which is different from his and I would like the colored backgrounds of the indicator to go over my candlesticks, in the foreground. Is it possible to do this? I didn't find it in the settings and I didn't see anyone talking about it on the forum. You can see the colored background at the arrows behind candlestick. |
[2021-04-21 16:58:44] |
John - SC Support - Posts: 38157 |
You can not specifically put the candlestick behind the Numbers Bars bars. But, you can change your candlestick to be hollow instead of filled. Refer to the following: Numbers Bars: Candlestick Outline For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-21 17:30:04] |
ISB3 - Posts: 11 |
Okay that's perfect for me! Thanks for the fast answer! Kind regards |
