Date/Time: Mon, 25 Nov 2024 21:55:15 +0000
Does TT Fix price feed and additional sierra chart feed for eurex work toegether?
View Count: 1010
[2014-03-08 01:22:14] |
User63439 - Posts: 83 |
hope question is clear? thanks in advance |
[2014-03-08 03:27:16] |
Yes. Both data feeds do work together.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-08 03:27:36
