Date/Time: Wed, 19 Mar 2025 09:14:30 +0000
Connecting multiple accounts
View Count: 2776
[2021-04-21 00:24:47] |
malik3103 - Posts: 6 |
is it possible to connect 2 or more diffrent trading accounts together? if yes , how ?
[2021-04-21 04:24:25] |
We see you are using Rithmic, so yes if they are associated with the same Rithmic username, then you can just select them from the Trade Window: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-22 22:23:28] |
i mean with 2 diffrent Rihtmic accounts
[2021-04-23 14:16:38] |
John - SC Support - Posts: 38782 |
If they are not accessible using a single login, then it is not possible to connect the accounts with Sierra Chart. You can use 2 different installations of Sierra Chart in order to trade each account, but you can not have trades apply to both accounts from just one Sierra Chart installation. Refer to the following for how to install a second Sierra Chart and set it up for your second trading account: Using Multiple Data and Trading Services at the Same Time For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-03 06:08:36] |
TekinTrading - Posts: 8 |
Isnt it a good idea for the future, to couple different trading accounts? It works on different plattforms as well I guess.
[2022-10-19 23:13:50] |
SJ305 - Posts: 3 |
The ability to copy trades between multiple rithmic logins would be great. Please consider for future updates.
