Date/Time: Tue, 25 Feb 2025 16:07:51 +0000
lost data
View Count: 535
[2021-04-21 00:24:38] |
drchadbaginski - Posts: 3 |
i've always used cqg data. it doesn't work on sierra chart anymore. i stopped using sierra chart when i lost my data feed. can i get a free trial of sierra data to see if i want to continue to use sierra chart?
[2021-04-21 00:55:17] |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". ---- Follow the instructions here to use CQG: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-21 00:55:42
