Date/Time: Tue, 25 Feb 2025 16:33:51 +0000
[Programming Help] - is there any way to use ACSIL to sum imbalances?
View Count: 582
[2021-04-20 20:10:04]
User61576 - Posts: 445
pls see attached screenshot
I would like to sum the imbalance volume/side
is there a way to do this with ACSIL?
imageScreenshot_6.jpg / V - Attached On 2021-04-20 20:08:17 UTC - Size: 84.4 KB - 227 views
[2021-04-20 21:59:31]
Flipper_2 - Posts: 57
Yeah you would use this,
ACSIL Interface Members - Variables and Arrays: sc.VolumeAtPriceForBars
find the level and side and store it in a SCSubgraphRef or something then just use the
ACSIL Interface Members - Functions: sc.GetSummation()
to sum how far you want to.
[2021-04-21 10:12:46]
is there any code example I can use see to learn how to implement it?
[2021-04-21 10:22:26]
from the like I posted.
For an example on how to use sc.VolumeAtPriceForBars, refer to the function scsf_VolumeAtPriceArrayTest in the /ACS_Source/studies8.cpp file in the folder where Sierra Chart is installed to. Or refer to scsf_VolumeWeightedAveragePrice in /ACS_Source/studies2.cpp. Or refer to scsf_VolumeAtPriceThresholdAlertV2 in /ACS_Source/studies8.cpp.
