Date/Time: Tue, 25 Feb 2025 16:00:10 +0000
i cant find my clipboard i saved the chart window to ?
View Count: 540
[2021-04-20 17:58:23] |
User431357 - Posts: 27 |
i sent screen shots of my chart window and my problem is i cant fit my heatmap on the chart display with the rest of my charts . I can only minimize it down below to my chart bar , or maximize it to expand. Im trying to click restore, to shrink it, just a little so i can adjust it to fit with the rest of my charts on my screen when im trading . |
[2021-04-20 18:06:30] |
John - SC Support - Posts: 38157 |
Unfortunately, without information on each of the images, we really do not understand the issue or see what the problem is. Offhand, from what you state, it sounds like the particular window you are having an issue with is Detached from your main Sierra Chart window. This would make it separate from the Sierra Chart window, unlike the other ones that are contained within it. Refer to the following: Detaching and Attaching Chart Windows If it is something else, then we just need more information on exactly what is happening. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
