Date/Time: Tue, 25 Feb 2025 16:14:17 +0000
i cant put orders whit denali
View Count: 543
[2021-04-20 16:31:24] |
User481662 - Posts: 4 |
im already change my data from cqg(amp futures) to use Denali with routing service, when i going put orders, sierra chart just put it in simulation mode automatically, im did the configuration but im only received and i cant put orders.
[2021-04-20 16:39:14] |
Who is your futures broker currently?
[2021-04-20 18:52:01] |
Amp futures
[2021-04-21 04:18:32] |
You still need to use CQG for order routing. You need to follow the step-by-step instructions here: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
