Date/Time: Tue, 25 Feb 2025 16:30:14 +0000
I switched to Denali time
View Count: 610
[2021-04-20 16:28:49]
User312232 - Posts: 2
I switched from Denali realtime from CQG and today there was a no data from 11:10 to 11:58 CST. I checked time and sales and there is a block missing even after a restart. Will they ever repopulate? Is there a problem with my account? Did I configure my services correctly? Am I using Denali real time?
[2021-04-20 17:16:57]
John - SC Support - Posts: 38160
Everything looks good in terms of your account and the Denali Exchange Data Feed setup.
Go through the instructions in this section to ensure you have everything set correctly:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
After you finish the above, you should have the [M] after your symbol in the Chart Header. If you do, then go back to the section of the missing data and follow these instructions to get the missing data:
