Date/Time: Tue, 25 Feb 2025 15:51:57 +0000
Will TT account be created by broker or by clearing house?
View Count: 552
[2021-04-20 16:26:05] |
User736769 - Posts: 1 |
Hi, I do not want to waste your time, and I hope I am not. I'd been browsing Sierrachart website for the last couple weeks trying to figure everything out myself. I tried searching this question on Support portal but no results. I came upon "Easy Solution to CME Funded Trading Account Requirement" and decided, and have, opened an account with Futurepath trading so that I can create an account with ADM Investor Services so that I can use Sierra Chart Order Routing Service. It was mentioned in the solution step 3 that you will contact my broker to have a TT (Trading Technologies) account created. I wanted to clarify with you if you will need permission from Futurepath to create this TT account, or is it the clearing house (ADM) that you will be contacting? I want to know because I kinda used Futurepath to create the ADM account but have no intention of using them for trading. Thank you, Marinel |
[2021-04-20 16:40:12] |
ADM does not support the Sierra Chart Order Routing Service. So neither in this case would be creating the TT account and normally that would be done by ADM though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
