Date/Time: Tue, 25 Feb 2025 16:18:17 +0000
Denali feed connectivity and use
View Count: 552
[2021-04-20 16:25:49]
User868766 - Posts: 11
Currently i would like to join a prop firm and they provide a rithmic data feed and currently am aware that sierra no longer supports Rithmic unless i have an older version before 2021 and use suggested bridge connections , because i love sierra and would like to continue using it , so is it possible to just use it for Charting only and use R-trader pro for executions.
Worst case scenario i may have to use Denali , but i would love to use for only charting and no broker connection and executions , so my question is , can the Advanced + Denali connection cost of 46$ a month be the only fee to pay or actually its more than that , if i just want only charting and not broker connection or execution.
I hope i will get a reply and greatly appreciate the help and service you have done for all traders
[2021-04-20 16:31:03]
You do not need an older version of Sierra Chart, we do not know how you come to that conclusion, and there is new Integration available for Rithmic. We are finalizing the details related to that.
Yes.
You do also have to pay for the exchange fee:
Denali Exchange Data Feed: Supported Exchanges (Exchange Fees)
And you also have to authorize the CME data which would require connecting to Rithmic:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
Date Time Of Last Edit: 2021-04-20 16:31:19
[2021-04-20 16:42:03]
So when you
. Are you going back to the past arrangement that used to exist before you guys had shut the door , or this is something entirely different but arriving to the conclusion of Rithmic connectivity back into Sierra
And will the new Integration allow for existing features still be used and trading connectivity especially for those who use rithmic with Remote Prop firms like one-up
well i didnt arrive to that conclusion but it was stated that as of 31st Dec 2020 Sierra would stop Supporting Rithmic and to remain using Rithmic in Sierra , you would need Bridge connectivity and an older version before 31st Dec 2020
Anyway but right now can Rithmic still be Connected using Bridge connections?
And my hope is that in the future Rithmic will be fully supported , thanks
Date Time Of Last Edit: 2021-04-20 17:22:43
