Date/Time: Tue, 25 Feb 2025 16:18:08 +0000
Hi I would like to use your data
View Count: 449
[2021-04-20 16:24:55] |
User772468 - Posts: 1 |
Hi I would like to use your data, how can I do it, I am not very familiar with your platform, I would like to use package 3 and your data, before I used cqg, thanks.
[2021-04-20 16:32:26] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
