Date/Time: Tue, 25 Feb 2025 16:00:14 +0000
AMP declined Opening Account request, other possibilities?
View Count: 619
[2021-04-20 13:30:20] |
anas mhana - Posts: 5 |
I have tried to open an account in AMP but my has been declined because they said "Syria is currently on AMP's restricted country list. At this time, AMP cannot accommodate an account for you". (although I have permanent residence in germany, Amp declined my request). Is there any clearing firm like AMP (which supports sierrachart) in Europe?
[2021-04-21 06:37:27] |
Check with the other supported brokers here: https://www.sierrachart.com/index.php?page=doc/OtherSitesLinks.php Also have a look at this page: CQG Trading Platform Service: Setup Instructions Although we would think if the broker is under US regulation there may be a problem, unfortunately. Although we would not think there would be a problem if you are residing in Germany. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
