Date/Time: Tue, 25 Feb 2025 16:11:10 +0000
ChartBook TPO
View Count: 927
[2021-04-20 10:56:52] |
Davecodex - Posts: 7 |
Im new to sierra charts and currently trying to create a top chartbook without success, I went through documentation but I'm not getting the results I need any help maybe any of sierra support can provide me a chartbook that includes the following: Trading Index ES NQ My global time is set to Chicago time. The chart needs to display 2 profiles RTH and ON: RTH - Print letters VAL VAH POC IB VAl + VAH highlighted Green ON/Globex Same as above but VAL and VAH highlighted a different color. |
[2021-04-20 16:33:25] |
John - SC Support - Posts: 38158 |
You would have to use a second chart and put the TPO Value Area Lines study on that chart for the overnight session and then set to the colors you want. Then use the Study/Price Overlay to overlay those Value Area Lines onto the TPO chart. Refer to the following: TPO Value Area Lines and the following: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-21 09:34:15] |
I have been given some charts from my mentor and they are worked on EST time frame, I have heard that if there is any time setting off this will give wrong data, is it true? if yes, what's the best practice to make sure everything is set up correctly? |
[2021-04-21 09:34:33] |
I am in GMT+1 time
[2021-04-21 14:09:58] |
The time zone setting only has an issue at the Daylight Saving changes, since the US changes at a different day from most of the rest of the world. Therefore, in order to avoid issues at those days, we recommend setting your time zone to one of the US time zones (typically Eastern or Central, as these are where the main exchanges are located). Otherwise, there is no issue with the time zone and data. For more information, refer to the following: Time Zone Setting: Resolving Differences with the Transition To/From Daylight Savings Time in Different Time Zones For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
