Date/Time: Fri, 02 Oct 2026 11:10:47 +0000
Number bars automatic scaling of tick size
View Count: 1630
[2021-04-20 02:29:44]
User872151 - Posts: 19
Hi dear Sierra Chart team,
have an issue with the scaling of the displayed volume profile within number bar candles which ideally should be automatic based on a changing tick size value.
For example if I have an AAPL chart and the number bars have rows of $0.25 and the trading range for the past 30 candles has been $5, then I have 20 rows displayed, but if volatility goes up and the trading range changes to $10, then I have 40 rows displayed. So basically I always have to change the row height depending on the volatility of the stock. Was looking for a solution where no matter the volatility always 30 rows are displayed and the row height will be automatically adjusted depending what the volatility is.
Cheers and thanks in advance!
[2021-04-20 14:08:41]
John - SC Support - Posts: 48086
There is no automated method for this.
Refer to the following setting which can be used to aggregate levels together:
Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu)
