Date/Time: Sat, 09 Nov 2024 23:14:52 +0000
graphics linking
View Count: 982
[2014-03-07 20:26:21] |
User872972 - Posts: 2 |
Hi I am wishing to link two chart books If i open a 5 min EuroUsd chart in chart book 1 and the same in chart book 2. What i wish to accomplish is that if i draw a line or a rectangle or whatever on chart book 1 (not studies) that it will also appear in chart book 2 without me having to duplicate the drawing. Possible? |
[2014-03-08 03:44:35] |
Yes this can be done. Refer to: https://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#CopyChartDrawingsfromChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
