Date/Time: Tue, 25 Feb 2025 16:21:12 +0000
Separate Text Coloring in Numbers Bars Issue
View Count: 446
[2021-04-19 22:40:46] |
cmet - Posts: 650 |
With "Use Separate Colors for Text Coloring Method" option set to "Yes", the last option in the Text Coloring drop down, "Based on Diagnonal Dominant Ask Vol Bid Vol - Actual" will only use the Column 1 coloring scheme. It doesn't use the coloring from the Range settings. Looks like this is the only option that does this. All others seem to use the Range colors. Not sure if I'm doing something wrong but maybe you can take a look when you get a chance. |
[2021-04-20 13:54:58] |
John - SC Support - Posts: 38159 |
We have fixed this issue. It will be in the next pre-release (v 2251).
