Date/Time: Tue, 25 Feb 2025 16:24:27 +0000
SC through APM Futures
View Count: 653
[2021-04-19 21:09:52] |
User246178 - Posts: 4 |
Hi. I've been using SC through AMP Futures. Should I open new account or just update my info and add usage credit on this account?
[2021-04-19 21:13:40] |
John - SC Support - Posts: 38160 |
You should just continue to use the same account. This way everything stays the same and all you need to do is add the Usage Credit. Which you can do from this page: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-20 15:44:24] |
Full information about this is here: Notice: Transition to Direct Sierra Chart Billing For SC Accounts through Broker Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
