Date/Time: Tue, 25 Feb 2025 14:01:25 +0000
trial period - can't seem to get data to update
View Count: 548
[2021-04-19 19:11:38]
User620369 - Posts: 3
Although charts load data up to the time they are created or opened, they do not update continuously. The message log is attached.
thanks for the help!
RexP
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=50382
[2021-04-19 19:39:17]
John - SC Support - Posts: 38150
Refer to the following link for what Real-Time data is included with Sierra Chart:
Real-Time Data
And also refer to the following for information on the Delayed Streaming Data that is also available at no extra cost. You just need to fill out the Exchange Agreements for the data:
Delayed Exchange Data Feed
And finally, if you are interested in Real-Time futures data, then refer to the following:
Is Historical and Real-time Futures Data Included?
