Date/Time: Tue, 25 Feb 2025 14:00:45 +0000
Binance data and depth
View Count: 567
[2021-04-19 16:32:44]
samual sprat - Posts: 343
Not sure if there's something wrong with the feed or if my package isn't high enough to enable depth bars, but I'm using Service Package 3 atm, can you tell me if I should be able to use "Bid & Ask Depth Bars" on this package with the Binance Futures perpetual contracts feed? It was working for me previously but I switched to package 3 and that may have broken it. Not sure.
If I upgrade to Service Package 5 will I be able to use Market Depth Historical on the Binance feed along with Bid & Ask Depth Bars?
S
[2021-04-19 17:32:44]
John - SC Support - Posts: 38150
You should be able to get the Bid and Ask Depth Bars with package 3.
If you want the Market Depth Historical Graph, then that requires Package 5.
Refer to the differences between the packages here:
Description of Service Packages and Pricing: Packages
