Date/Time: Tue, 25 Feb 2025 14:05:17 +0000
Pull/Stack sums not available in replay
View Count: 505
[2021-04-19 16:31:37] |
User145575 - Posts: 20 |
Hello, I've been playing around making an indicator based on the "Sum Bid Pull/Stack" and "Sum Ask Pull/Stack" subgraphs of the "Numbers Bars Calculated Values 2" study. However, those are all "0" in replay, which makes it hard to test. I do see the pull/stack DOM columns populated during the same replay session. And it all works fine during live (non-replay) time. I even see other subgraphs of Calc Values 2 being populated in replay. Just not these two that I need. Is there something that I'm missing, or is this just not supported? I'm hoping not to have to resort to ACSIL for this, as it is already so close... I just need to be able to test different settings in replay. Thank you! |
