Date/Time: Tue, 25 Feb 2025 16:01:45 +0000
Alert Manager Window
View Count: 513
[2021-04-19 14:18:47] |
Ricardo Zurek - Posts: 18 |
I have a time and sales window with alerts when there is a 100 lot single trade. When there is a bid alert the alert manager opens automatically, how can I avoid this? (This doesn´t happen with my ask trades and started happening with the bid trades when I changed the alert sound)
[2021-04-19 16:33:30] |
John - SC Support - Posts: 38157 |
Check to see if the following option is enabled for the Bid alert number you have set, if it is enabled, then disable it: General Settings Window: Add Alert to Compact Alert Popup Window (Global Settings >> General Settings >> Alerts >> Additional Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-20 14:07:05] |
The Compact Alert Popup Window in disabled, what else could it be?
[2021-04-20 16:36:25] |
You need to disable this option: General Settings Window: Show Alerts Log On Study Alert (Global Settings >> General Settings >> Alerts >> Additional Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
