Date/Time: Tue, 25 Feb 2025 14:06:57 +0000
Lock Fill Space issue when maximizing window
View Count: 548
[2021-04-18 23:06:28]
User997450 - Posts: 17
On one of my charts I have the lock space perfectly aligned with a volume by price study filling the space to the right. When i maximize that window the bars overlap the study. Is there a way to fix that without having to adjust lock fill space every time I want to maximize that window?
Thanks!
[2021-04-19 00:14:53]
It should remain consistent. When you look at the lower right corner of the chart there is a number that indicates, the bar spacing in pixels:
https://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#LRChartSettingsIndicators
Does this number change when you maximize the chart? Although it could be that the Volume by Price study width is changing. You can control how that is determined:
Volume By Price Study: Maximum Volume Bar Width Type
Date Time Of Last Edit: 2021-04-19 00:16:02
[2021-04-19 00:51:28]
The bar spacing remains the same on both at 11 LE.
I have side by side volume profiles. One ETH and the other RTH. I have maximum volume bar width type set to window width and the width percentage set to 10. Maybe that has something to do with it??
image1.png / V - Attached On 2021-04-19 00:46:32 UTC - Size: 268.1 KB - 216 views
[2021-04-19 01:07:30]
File attached
image2.png / V - Attached On 2021-04-19 01:07:22 UTC - Size: 582.78 KB - 223 views
