Date/Time: Sat, 26 Sep 2026 17:20:42 +0000
Infinity DOM
View Count: 968
[2021-04-18 12:22:52]
User707404 - Posts: 34
When I change to the Denali Data Real Time service with Eurex, will I still be able to use the Infinity Futures DOM that I have been using? If so do I need to make any changes to the DOM's set up?
[2021-04-19 14:37:11]
John - SC Support - Posts: 48028
You can continue to use the Infinity Futures DOM, but you will then need to pay for the data from both TransAct and Sierra Chart. As the Sierra Chart data can not be used in other programs.
[2021-04-20 06:03:39]
Yes but the problem is, is that you need to pay the exchange fee twice so it would be better to switch to CQG or the Sierra Chart Order Routing Service and do all of your trading within Sierra Chart. For the supported services, refer to:
Supported Data and Trading Services
Sierra Chart also has a trading DOM:
Chart Trading and the Chart DOM
