Date/Time: Tue, 25 Feb 2025 14:09:36 +0000
Cannot find vcvarsall.bat. It does exist in VS140COMNTOOLS path.
View Count: 799
[2021-04-18 11:38:00] |
jwick - Posts: 142 |
Hi, I am getting the following error when trying to compile ACSIL. It began after I did the following two things: Ran windows update and restarted + updated SC. C:\Windows\system32\cmd.exe /C "C:\SierraChart\SierraChartInstance_4\ACS_Source\VisualCCompile.Bat" C:\SierraChart\SierraChartInstance_4\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\vcvarsall.bat" amd64 '"C:\Program Files (x86)\Microsoft Visual Studio 14.0\vcvarsall.bat"' is not recognized as an internal or external command, operable program or batch file. C:\SierraChart\SierraChartInstance_4\ACS_Source>cl /Zc:wchar_t /GS /GL /W3 /O2 /Zc:inline /D "NDEBUG" /D "_WINDOWS" /D "_USRDLL" /D "_WINDLL" /Oy /Gd /Gy /Oi /GR- /GF /Ot /fp:precise /MT /std:c++17 /LD /EHa /WX- /nologo "C:\SierraChart\SierraChartInstance_4\ACS_Source\OFTCode.cpp" /link "Gdi32.lib" /DLL /DYNAMICBASE /INCREMENTAL:NO /OPT:REF /OPT:ICF /MACHINE:X64 /OUT:"C:\SierraChart\SierraChartInstance_4\Data\OFTCode_64.dll" 'cl' is not recognized as an internal or external command, operable program or batch file. -- End of Build -- 07:25:52 When I ran echo %VS140COMNTOOLS% in the command line I got: C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\Tools\ EDIT: Updating to the pre-release version fixed this. EDIT2: Well shucks ... the pre-release version of SC crashes when I load my chartbook (loads fine in regular release) EDIT3: To summarize: v2246: No issue (currently downgraded to this version) v2247: Cannot find vcvarsall.bat issue. No crash when loading chartbook. v2250 pre-release: Able to find vcvarsall.bat / no compilation issue. Chartbook crashes on load. Date Time Of Last Edit: 2021-04-18 14:48:19
[2021-04-19 14:35:23] |
John - SC Support - Posts: 38150 |
Update to the current Pre-Release (v 2250) and then try to open your Chartbook in Safe Mode. Refer to the following: Sierra Chart - Software Login Instructions: Using Safe Mode If it loads fine, then the problem is a study that is not from Sierra Chart. You will need to work through what study is causing the issue and why. Otherwise, if it still crashes when trying to open the Chartbook in Safe Mode, then attach the chartbook to this thread so we can take a look by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
