Date/Time: Tue, 25 Feb 2025 14:09:59 +0000
v2249 - Drawing Tools Exception
View Count: 577
[2021-04-17 15:49:28]
User907968 - Posts: 833
I am seeing a problem in pre-release v2249 with custom studies that use drawing tools, and that were compiled for earlier versions of Sierra Chart.
One particular example is a memory access violation when calling 'sc.GetACSDrawingByLineNumber()', but this is as far as I've got.
From the studies that I've tested:
1) Studies built for version 2196 thru 2247 work as expected up until, and including, 2248.
2) Using the same studies in version 2249 leads to exceptions, and in some cases immediate termination of the program.
[2021-04-17 22:00:41]
We are checking on this now. It must relate to the new symbol member. That member should not be set with older compiled code so we have to see what the issue is.
[2021-04-18 02:01:19]
We have determined the problem. It is rather complex. We are implementing a partial solution in the next release coming out now.
[2021-04-18 08:20:00]
Ok, so I did a quick test of v2250 and the issue persists.
[2021-04-18 19:51:40]
There is more work that is needed. We will have it done today.
