Date/Time: Fri, 25 Sep 2026 08:19:54 +0000
Bar period type - specific
View Count: 812
[2021-04-16 07:42:26]
manfretto - Posts: 119
I would like to make a 1 tick without gaps chart as enclosed.
Regarding volume and tick summary is it possible only thru zig zag?
imagesc.png / V - Attached On 2021-04-16 07:42:14 UTC - Size: 94.08 KB - 324 views
[2021-04-16 16:17:09]
John - SC Support - Posts: 48003
We can't say exactly what kind of chart that is. There are a lot of possibilities. Our best guess from what you state is that you are looking for a Range chart with a 1 tick range. Refer to the information starting at the following and going down through the Range Bar types:
Chart Settings: Range Per Bar - Standard (in ticks) (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period Settings >> Bar Period Type)
We are not sure what you are asking in terms of Volume and Tick summary. From what is displayed in the chart, if you are looking for the information for each "leg" of the zig zag in the chart, then the best way would be the Zig Zag study. Otherwise, there are other studies you can use, or even the Chart Calculator. Refer to the information for the Zig Zag here:
Zig Zag
