Date/Time: Tue, 25 Feb 2025 14:19:54 +0000
Brokerage Firm
View Count: 523
[2021-04-16 00:22:57] |
User205196 - Posts: 2 |
I am currently with Amp Futures. I just reactivated my account with them. Also just signed up with Sierra Chart Will Denali support Amp as my trading service?
[2021-04-16 02:57:38] |
I am unable to connect to any data stream on the SC. I have already paid for 6 Months of SC with Denali data feed in addition to the $31.21 for Denali data feed. Amp futures is my trading service. How do I connect to a data feed on The SC software? I have ready went to Global settings and was unable to find any of the feeds enabled. Your help would be much appreciated
[2021-04-16 13:59:27] |
John - SC Support - Posts: 38150 |
You need to connect your Sierra Chart software to the trading service you are using with AMP. Most likely this is CQG, in which case follow the instructions at the following link to get setup: CQG Trading Platform Service If you do not have the CQG information from AMP, then you need to let them know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-16 14:28:49] |
And yes, the Denali Exchange Data Feed will work with AMP and CQG. It works with any broker and trading service.
