Date/Time: Tue, 25 Feb 2025 13:16:07 +0000
Sierra open positions from one computer to another
View Count: 538
[2021-04-15 17:20:43]
DayTraderEsad - Posts: 121
I normally trade on my desktop and wanting to have access on my laptop. As I am leaving in the afternoon for remote work. When I downloaded Sierra on my laptop and opened it up. I used the same chartbook from my desktop to pull up my execution chartbook. It had all of the DOM's, but it did not connect to all of the accounts and the accounts it did connect, it did not show the open position that it had. Showed everything flat. Is there something extra that needs to be activated?
I did have the desktop sierra shutdown while trying to run it on the laptop.
Thanks for your help.
[2021-04-15 20:25:18]
In your case you are using the Sierra Chart Order Routing Service. So make sure Sierra Chart on your laptop is configured to use that service:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
