Date/Time: Tue, 25 Feb 2025 12:55:38 +0000
Chart cancel order 'X' position - right or left
View Count: 457
[2021-04-15 16:36:50] |
Dean Roberts - Posts: 79 |
Hi All I can't seem to find out where I can select the position of the 'X' on a chart order line. On some of my charts it's against the text of the order on the left of the screen and on others it's on the right against the price axis. I'm sure I changed this ages ago but it's not in the Chart Trade Settings. Much appreciated Dean |
[2021-04-15 16:47:07] |
John - SC Support - Posts: 38150 |
You will find this setting under Chart >> Chart Settings >> Advanced Settings >> Align Order Cancel (X) Button To Right. Refer to the following: Chart Settings: Align Order Cancel (X) Button to Right (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
