Date/Time: Wed, 05 Nov 2025 05:51:23 +0000
Horizontal Line Text/Label and Midpoint Marker
View Count: 727
| [2021-04-15 10:39:05] |
| Steve Leon - Posts: 319 |
I am trying to figure out 3 things and was not able to make any progress despite my investigations 1) I wanted to know if there is anyway to customize Horizontal Line Tool associated text ? For example If I place a Horizontal Line on my chart with using the tool, i see i can label the line but the label will be the same color as the line and i cant change the label the same way i can on say a subgraph study 2) Is there anyway to create a horizontal extension line for the midpoint marker itself on the TPO study. I know you can find the midpoint on the study section H+L/2 and label that but I wanted to know if there is anyway to do something similar using the midpoint marker on the data study 3). I am not that familiar with spreadsheets but i wanted to know if i create a spreadsheet would i be able to take those inputs and somehow sen them to be used to create horizontal lines at those specific points ? Thank you |
| [2021-04-15 15:48:11] |
| John - SC Support - Posts: 42772 |
1. The color of the text is the same as the color of the drawing. There is no way to have them different. 2. There is not a way to do what you are asking from the midpoint of the TPO study itself. 3. We are not sure exactly what you are asking here, but you can create a horizontal line through the Spreadsheet by having a single value for all cells in a column. You could always base this on some set of criteria as well. Refer to the following: Using the Spreadsheet Study: Step By Step Instructions to use the Spreadsheet Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
