Date/Time: Tue, 25 Feb 2025 13:18:07 +0000
SC V2247 has wrong path in VisualCCompile.bat
View Count: 796
[2021-04-15 05:03:18]
User553714 - Posts: 184
I recently updated to SC V2247; when I try to build a custom study via the menu's Analysis>>BuildCustomStudies it gives the following error;
C:\SierraChartB0\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\vcvarsall.bat" amd64
'"C:\Program Files (x86)\Microsoft Visual Studio 14.0\vcvarsall.bat"' is not recognized as an internal or external command,
operable program or batch file."
Previously the path included the VC sub-directory IE; C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat
When I manually changed this path inside "VisualCCompile.bat" and run the file from inside the ACS_Source folder, the bat runs fine and my code compiles.
Can you please make the changes so the correct path is used via the SC build menu?
[2021-04-15 15:05:38]
ForgivingComputers.com - Posts: 1012
This was addressed in another thread. You need to install the pre-release version.
[2021-04-15 15:32:19]
Update to the latest prerelease to resolve this:
